- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1200 Wifi Range Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
The model pic list does not show my model which is EX6110-100UKS.
This is operating but does not extend the range of my router. It has setup another connected network which is only accessed when directly connecting to that network with the -2GEXT suffix. How can I configure this to actuallt EXTEND my present network ?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1200 Wifi Range Extender
Hi @heaucp1,
Do you see Router LED turned ON? If so, setup went through fine. You'll be able to access extender's settings using mywifiext.net from any device which is connected to extender's network or from other devices on network using its IP address which can be located from connected devices of your router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks but are you saying that I can configure the extender to use the same network address as my router network name (SSID)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
