- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1900 and a another Netg Wireless router and then a xfinity router. I need to add wired devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
I need to add security cameras past my nighthawks extenders (2). I have the range extendes going to the far side of my house, but I now need to add an ethernet NVR to the farside. Can I connect ethernet to a nighthawk that is setup as a wireless Extender? I am not seeing any wired devices?
Can I connect the other netgear router (possibly N600???) to the nighthawk and then add ethernet?
Layout is basically Xfinity-wireless>nighthawk1-wireless>nighthawk2-ethernet>NVR (or -wireless>Router-ethernet>NVR)
Can I add the other router as a wireless bridge? or something?
I cannot see the nvr if I connect it directly to the nighthawk#2.
both nighthawks are configured for wireless extenders.
The NVR used to be setup on the netgear router, and it WAS my access point before the house was rewired.
Thanks!
Bruce
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1900 and a another Netg Wireless router and then a xfinity router. I need to add wired devices
Ideally the comcast router connects to the other routers via catxx cable and they are set up in AP Mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do not have access to a cable directly (contractors cut wires, and need to get huose rewired, until thin, I need a "wireless" connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi mctabish,
What is the exact model number of your NETGEAR devices? Are those devices extenders or routers?
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is the Xfinity router (unknown model but just installed . Then I have 2 nighthawk range extendeds(AC1900) Then I have a N600 Router.
Can I add a wired device at the end of the chain past the nighthawks? There is NOT any ethernet access (from the Xfinity modem/router) to where the NVR is that I am trying to connect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I swore I sent this already!
I have an Xfinty modem/router (brand new X1-) then I have a night Hawk AC1900 setup as an wireless extender, the another night Hawk AC1900 setup as an wireless extender, and then I have a N600 router. There is NO ethernet connection between the modem/router (xfinity) and the N300. Where the N300 is (also one of the AC1900) is where I have my NVD (video recorder) that I need to reconnect.
My OLD comcast modem/router is at the location where the video recorder is, but I cannot move the NVR for a few months due to construction. I can ONLY connect SOMEHOW wireless.
Thanks!
Bruce
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just got a chance and it looks like the info I gave you are kinda generic models. Here is what I have found on the devices:
WNDR3700V3 router N600
EX7000 / AC1900
Thanks for ANY SUGGESTIONS!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello mctabish
You should be able to use the Ethernet ports on the extender just fine but the issue you may be running into is connecting a extender to a extender you are losing alot of signal doing that.
DarrenM
