RSM52
Nov 29, 2016Tutor
AC750 Range Extender does not work with Ethernet Cable
WIFI on extender working fine. When I plugged in my Win 7 machine it connected momentarily but will no longer connect. Any trouble shooting suggestions. I thought was just plug and play but perhaps there is a setting in Win 7 I need to modify? Appreciate the help.
- RSM52Tutor
An update - after speaking with technical support they informed me that only gaming consoles can use the ethernet port on the Extender. This makes no sense and defeats the purpose of having a remote ethernet port. I am hoping that a clever community member has found a workaround to this. There must be a way to get the extender talking to a Win 7 desktop?!? Help would be appreciated.
- DarrenMSr. NETGEAR Moderator
Hello RSM52
It should work on any ethernet device do you have the latest firmware? And when the connection goes out does it show up as a red x on the connection like no Ethernet is connected or does it just not connect to the internet anymore?DarrenM
- RSM52Tutor
Thanks for the prompt reply. I ended up buying a wireless adapter for 20 bucks which connects without a problem. Trying to get the computer working with an Ethernet cable seemed fraught with frustration.
