× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
AC750 WiFi range extender (EX3700)
huztimar
Dear community,
The product does not meet usability criteria!
4 meters between the router and the Netgear AC750 Wireless Signal Amplifier Adapter - ground floor and floor - while only the slab is there - but the reapeter no longer detects or barely detects the signals of the router. Upstairs, you can't even make a wifi connection because of weak, unstable router detection!
    • AC750 WiFi range extender (EX3700)
Does anyone have a similar problem?
Regards, huztimar
Model: Dual Band
Message 1 of 5
Guru
Re: AC750 WiFi range extender (EX3700)
You said "slab"
Are you talking a cement slab?
Message 2 of 5
huztimar
Part of it is, yes.
Bridging beams always contain cement.
@plemans wrote:
You said "slab"
Message 3 of 5
Guru
And cement and metal are literally the 2 materials that block wifi the greatest. Especially floor slabs as they tend to be thicker than wall slabs.
You're best bet? buy a cement drill bit and drill a hole through the slab to run an ethernet wire. Connect that to the extender and run it in AP mode.
Message 4 of 5
huztimar
That's a little funny.
Drill the slab. Maybe I should replace it.
I don't think we need to tear the house apart.
Example:
TP-LINK TL-WA850RE N300 300Mbps range extender is excellent for the router upstairs.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 713 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
