Parrotopia
Jun 25, 2020Follower
Access Point and Extender mode
If I have the first extender set up in Access Point Mode, must I keep the ethernet connection? I have two buildings with a garage between. The first building I live in - has the router. The second building I am trying to extend a reliable internet connection to. I put one extender in a location half way between the two buildings. It gives me internet in the second building but I keep loosing the connection. I bought a second extender for the second building. I am now trying to link them all together to give me a good internet in the second building. How to set up each extender?
1 Reply
How far apart are these?
You ideal setup is with a hardwired connection and not using wireless. The reason is a standard extender has to receive a signal and then rebroadcast it. And it can't do both at once. So it looses 50% of whatever throughput it had in that area. Add a 2nd extender and you're goin to be at less than 25%. Potentially much less depending on where each was located.
If you can hardwire in the devices, you'll have much better speeds/performance.
If thats not possible and the distance is to far for standard extenders, I'd look into netgears airbridge setup.
