mazzman
Apr 14, 2017Follower
Best WiFi Signal Strength Analyzer App for iPhone 6 or Mac
I see there is a signal strength analyzer for Android, but cannot find one in the Apple App store. I just want to see if it is worth getting the N300 WiFi Range Extender, since the Master BedRoom (on the far side of the apartment from the C3000 modem/wireless router) has pretty good but not great service.
Thanks!
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Mazzman
You might be able to find one in the app store or use the one built into the desktop genie app.
DarrenM
