- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't get extension WiFi to recognise my WiFi password
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't get extension WiFi to recognise my WiFi password
What router are you connecting it to?
Did you set it up using wps?
If so, factory reset the extender and install it using the installation assistant and not wps.
Wps can sometimes get coded different (or poortly) and not connect right. So try it using the installation assistant.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@vcx1 wrote:
I have turned it on, moved it away, then further away, all lights are on. When I look at my phone it comes up with the 2 WiFi extension options. I choose one/either and it asks for my WiFi password so I enter the 16 digit code, same as for my WiFi and it says password incorrect. I promise I have typed it correctly! What have I done wrong??
Which "password" are you using?
The wifi and the router have different passwords.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@vcx1 wrote:
I tried the installation assistant and at the end it required passwords and so still didn't work.
What installation assistant? A browser on a PC? An app on a mobile device?
@vcx1 wrote:
it just goes to a Netgear Web page which doesn't help and certainly no sign of the model number I have.
I'm afraid this doesn't tell us much. What "Netgear Web page"? What does it say?
Netgear devices should to take you to any "web page", which most of us think of as somewhere out on the Internet. You should arrive at the browser graphical user interface (GUI) for the device.
This is where you set up and control your extender.
Did you find the video on the support pages for your extender?
We still do not know what this vodafone modem/router is, so we can't tell what features it has.
Look all over it for a button with the label WPS. If you find it, press the button press the WPS button on the EX6110 and when ti start flashing press the WPS button on the vodafone thing.
With luck the two devices will see each other and set up a connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might try reading a bit on the vodafone forums about that router.
THG3000 Router Setup to TP-Link RE305 Extender - Community home (vodafone.co.uk)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@vcx1 wrote:
Vodafone does not support a 3rd party Extender.
This does not mean that you cannot get your extender to work. You just have to ignore the standard setup routine and go for a custom process.
If WPS won't work, try something like changing the wifi settings in your modem/router.
This is not the first time that your problem has hit these places:
Search - NETGEAR Communities – Vodafone EX6110
- Mark as New
- Bookmark
- Subscribe
- Permalink
User | Count |
2 | |
1 | |
1 | |
1 | |
1 |
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
