tdnishio's avatar
tdnishio
Device: Red light stays on N300 EX2700 even if plugged in next room
  • plemans's avatar
    Which red light? It has several led's.
    What router is the EX2700 connected to?
    Did you set it up using wps or using the installation assistant?
    • tdnishio's avatar
      tdnishio
      Red light stays on the Device.
      Router is from my internet provider Consolidated Communications.
      I believe it was installed using Netgear's installation protocol.
      If you need more clarity than what I have provided, please let me know, what more specific you need.
      • plemans's avatar
        tdnishio wrote:
        Red light stays on the Device.  ----Which led? That's key.
        Router is from my internet provider Consolidated Communications.---that told me nothing. What actual router is it?
        I believe it was installed using Netgear's installation protocol.----which protocol? there's more than 1 way to install it which is why I asked.
        If you need more clarity than what I have provided, please let me know, what more specific you need.----Yes I need more clarity. Actualy details helps. I'm not there to see whats going on or what you did so you need to be specific.
