- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EAX80 Setup problem - no internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Trying to setup EAX80 with Verizon MIFI. Tried two different MIFI units that are working fine and have internet connections. When I connect the EAX80 the internet connection is not realized. In each case the MIFI is working fine and I can connect directly with a laptop and get to the internet. Using the Nighthawk app for setup. Seems like this should work but clearly seems to be a systemic issue since I tried with 2 separate working MIFIs. Any suggestions before I send the Nighthawk back to Amazon?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Billaban wrote:
Nothing about a Installation assistant in the Nighthawk documentation. I found it online but the instructions require a working internet connection to do:
Sure it is, you already discovered. Consult the fine Nighthawk AX8 8-Stream WiFi 6 Mesh Extender Model EAX80 User Manual and you find the "NETGEAR Installation Assistant" on page 16 Connect with the web browser setup.
@Billaban wrote:
5 Enter (forum blocked URL) or 192.168.1.250 in the address bar of your browser.
The New Extender Setup page shows.
Follow all steps. It does start with this:
1. On your WiFi-enabled computer or mobile device, open the WiFi connection
manager and locate and connect to the extender network called NETGEAR_EXT.
This means using your computer or mobile associated with the factory default Wi-Fi on the EAX80.
If your EAX80 was configured before, use the reset button as shown on p.49.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EAX80 Setup problem - no internet
did you try using the installation assistant?
Does the mifi have ethernet out? Could always connect it hardwired in running in access point mode. It'll have a lot more power than the mifi's wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
The MIFIs do not have ethernet out port.
So that isn't going to get me anywhere since the root of the evil is I can't get a working internet connection via the EAX80.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You don't need a working internet connection to use the assistant.
You start it at factory, connect to the extender, and when you enter one of those addresses, it takes you through the assistant. I do it all the time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK. This sounds promising but I'm lost as to what "You start it at factory," means. Can you elaborate? Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So after several factory resets and more than you want to read about I got it working. Thanks for the guidance. I'm modestly concerned that the whole setup (so far) has been flakey, e.g., several attempts to get expected behavior.
What I really want to accomplish is setting up a mesh system for our sprawling old house and EAX80 was purchased to provide the required port (that I don't have w/ a MIFI) to facilitate the mesh hardware connection. Is this going to work? Any suggestions or comments?
TIA
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I'm not sure how this will work either. Was going to get StarLink but the price has become just silly. We live in the country. Big house bed & breakfast. Have two MIFIs here and another at an additional house on the property. Have been using the MIFIs for years with few issues. Occasionally a guest will whine about the bandwidth but I know I can stream video when needed and I know that some people aren't happy unless they have something to **bleep** about. More than a few years ago I worked fulltime remote as a S/W systems engineer and rarely had issues with my full tunnel connection back to the office using just a MIFI.
The EAX80 and mesh setup is more about coverage than bandwidth expectation. The Netgear RBK753 is expected to arrive on Monday. The experiment will continue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You have a total of 3x mifi's? Thats a bit of an investment right there in monthly fees.
Might be worth switching to starlink and getting a point to point system like netgear's airbridge to cover the whole property.
The airbridge can connect the buildings and put a satellite in each for the wireless coverage.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
