× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX 8000 - Tri band - How enable its band 3 (up to 1733Gbps)
Willywood
Follower
Hello guys,
I have some problems with my EX8000 since i reset this access point :
i only have two band (one for 2.4 GHz and one for 5GHz).
Before the reset of the AP, i had 3 band (1 for 2.4Ghz, another one for 5GHZ up to 800Mbps and the last one for 5GHZ up top 1733Mbps),
how can i activate this band : Band  3 1733Mbps @5Ghz 256 QAM ?
Thank you !
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 2
Guru
Re: EX 8000 - Tri band - How enable its band 3 (up to 1733Gbps)
After the reset, did you reinstall it in access point mode?
In access point mode, all 3 bands are usable.
In extender mode, it uses a dedicated link back to the primary router that isn't usable.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 330 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
