Orbi WiFi 7 RBE973
Reply
EX2700 Connected No Internet
Billblackwell
Device has been working fine for months and now it connects like I always did but now it says No Internet.
I have updated the firmware on my Router to the newest thinking that may fix the problem. Still doesnt work.
Router is a EA4600 Linksys. I also has reset extender multiple times and read almost all the threads on this forum that has anything to do about this problem and none of the things I have tryed have worked. Most are older threads though. Any help available on this?
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 1 of 6
Christian_R
NETGEAR Employee Retired
Re: EX2700 Connected No Internet
Hello Billblackwell - Would you mind providing us with the LED light status of the extender along with the firmware version the extender is currently on.
~Christian
Message 2 of 6
Billblackwell
Installed V1.0.1.52 firmware
Still shows the same.
All lights are green
Message 3 of 6
Christian_R
Billblackwell - Factory reset the extender by pressing on the small black button using a pin for 15+ seconds then join the NETGEAR_EXT wifi network using a phone or laptop. After you connect to the NETGEAR_EXT network with your phone or laptop, browse to www.mywifiext.net and follow the setup instructions.
Please let me know during what step of this process you run into issues with. I would recommend setting up the extender in the same room as the router before moving it to the designated area.
~Christian
Message 4 of 6
Billblackwell
Went all the way through your instructions.
It acts like everything goes good (login etc)
After login......
Still the same. I bought a new one and it works fine.
Gonna toss this one.
Thanks for your efforts....
Message 5 of 6
raroboy
I found the solution after countless hours checking forems to no avail. For me it was to disconnect VPN. Then you can access WWW.mywifiexp.net and set up. I discovered this because I could set up from my phone and I could access internet through the extender. Let me know if this also solves your problem
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 4129 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
