× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX2700
inesllopart
Initiate
EX2700
Hi, I have an old Wifi Extender at home and I am trying to follow the device's instructions.
However, when the Power LED goes green no wifi network shows up to start the setup. Has this happened to anybody else? Any ideas how to solve it? My router also does not have a WPS button.
Thank you!
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 1 of 4
Accepted Solutions
Guru
Re: EX2700
did you factory reset the extender? Maybe an old ssid is broadcasting.
Push and hold reset for 7-15 seconds while its powered on. Then try setup
Message 2 of 4
All Replies
Guru
Re: EX2700
Message 2 of 4
inesllopart
Initiate
Re: EX2700
Thank you! It turns out I wasn't holding the reset button for long enough
Message 3 of 4
Guru
Re: EX2700
Glad it was something simple! 🙂
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1412 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
