× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX2700
jda1912
Follower
EX2700
Using two extenders. On android wifi networks available _EXT and _Ext.
Need to add a third. What will extension be for this new one?
_Ext2???
Regards
John
Message 1 of 2
Guru
Re: EX2700
Anytime people are needing more than 1 extender, I recommend moving to a mesh system.
Using multiple extenders tends to create stability and interference issues.
And if you're going to do it, make sure they're setup in a star topology and not daisy chained.
If you're doing it, use the installation assistant and NOT wps for setting up the 3rd device. then you can name it what you want.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 451 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
