WaltS's avatar
WaltS
EX6100 Access Points
I'm trying to use two EX6100s in a church with steel beams and floors. I've run two Cat 5e lines to different locations. I set the first up and it works great.  But when trying to configure the second, my browser picks up the weak signal from the first rather that the second.  What is the best solution?  Shut the first unit down, do the install on the second and restart the first?  Something else?  Can I use the same SSID and keys on both devices or must they be different?
Thanks for the help.
  • Hello Walts
    Yea I would turn one off to set up the other one or you would have to go to your main routers attached devices page and find the IP of the second Ex6100 and use that in your web browser to get to the extenders GUI.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello WaltS
    You may want to factory reset the second one try the setup again. Also try to adjust your wireless channel on your main router to get the best signal on the router and the extender. As for the name you can have them named the same but it could cause some issues since they are all individual wifi networks so they will not hand off the wifi signal to the best signal if you are moving around.
    DarrenM
  • This gets me some of the way to a solution. Again, I'm using these devices as access points, NOT extenders, so the discussion regarding wireless channels does not seem relevant, or am I missing something? I'm trying resets on both devices and setting each up with the other turned off to see if I can get them working correctly.
    • DarrenM's avatar
      DarrenM
      Hello Walts
      DarrenM
