× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX6100V2 Range Extender - Channel numbers and 3 extenders in use.
D-Lary
Follower
I have 3 AC750 Netgear range extenders setup in my home.  Should they all be on the same channels or different ones.
Example:  2GHZ band is on channel 01 and 5GHZ band is on channel 40 on all 3 range extenders.
Should each extender have a different 2 channel set?
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: EX6100V2 Range Extender - Channel numbers and 3 extenders in use.
The extenders will follow the same channel that the router is on so they would be the same.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 596 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
