× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX6120 green blinking power light
Glenn88
I installed the extender and set up my network.  After that process, I was asked if I wanted to update the firmware.  I had to step away for a few minutes after that started.  Afterwards, I saw only a green blinking light -no router or device light.  I have turned off/on and get a solid amber boot light, then blinking green light.  I have tried resetting to factory settings and nothing happens, just blinking green light continues.  Pushing the WPS button, nothiing happens -no blinking WPS light.  I have tried plugging in by ethernet with no results -no Device light.
My guess is something happened in the firmware update.  IS THIS DEVICE RECOVERABLE?
I went through trials when I had time to mess with it but now the 90 day warranty is expired.  I don't want to pay $49 for a phone call for a device that is available for $49.
Model: EX6120|AC1200 Dual Band WiFi Range Extender
Message 1 of 3
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: EX6120 green blinking power light
You could try to reflash the firmware via TFTP I linked below how to do this.
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
DarrenM
Message 2 of 3
All Replies
DarrenM
DarrenM
Message 2 of 3
Glenn88
Thanks.  It took me two tries to get the settings correct but it updated the firmware and works like new.  The first trial I may not have waited long enough for the setup.
Dual Band WiFi Range Extender / EX6120
Firmware: V1.0.0.32_1.0.21
Message 3 of 3
Discussion stats
  • 2 replies
  • 16158 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
