- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX6150v2 Failing to bootup after firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought an Ex6150v2 from ebay and did a factory reset to setup it as an extender. I went through the setup prosess and manage to setup as expected. Once I loged in to the extender home page it poped me up to update the firmware and I thought it would enhaance my extender performance. Sorry I can't remember its firmware versions. I wait till the update process ends and it didn't turn up. the power LED remaind amber. I though it takes longer and I waited to see it turns green more than half an hour.
I went through the community and found out manual flashing firmware with TFTP2 and I managed to flash the firmware succesfully but the issue is the same. I tried all the firmware available in the support page one at a time (even the beta hot fix) but non of the could fix the issue.
Any suggestions are appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6150v2 Failing to bootup after firmware update
If the unit was new that you bought off ebay I suggest contacting support.
http://www.netgear.com/support/contact.aspx
DarrenM
