Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX7000 Can not connect to the extender - password do not match
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-09-26
11:54 PM
2019-09-26
11:54 PM
Hi, the extender used to work just fine until I noticed one day it was no longer connected. Had to reconfigure it but since then I just can not connect it. I get an eeror message saying the password do not match altough it does.
I have tried to reset it but. still get the same error.
What is wrong and what can be done?
Thanks
Model: EX7000|AC1900 Nighthawk WiFi Range Extender
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-09-27
09:41 AM
2019-09-27
09:41 AM
Re: EX7000 Can not connect to the extender - password do not match
What firmware is on it?
have you tried a factory reset on the device?
If so, try reinstalling the firmware to it, then factory resetting it. Make sure to do it over a hardwired connection when you do so.
https://www.netgear.com/support/product/EX7000.aspx
Message 2 of 2
Announcements
