This topic has been closed to new posts due to inactivity. We hope you'll join the conversation by posting to an open topic or starting a new one.
NETGEAR ® COMMUNITY
  • Downloads
  • MyNETGEAR
  • Community
  • Netgear
  • United States
    • 中国 (汉语)
    • Deutschland (Deutsch)
    • España (Español)
    • France (Français)
    • Italia (Italiano)
    • 日本 (日本語)
    • United States (English)
cancel
turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Search instead for
Did you mean:
  • English
  • NETGEAR Forum
  • Home Networking
  • WiFi Range Extenders & Nighthawk Mesh
  • EX7000 Virtual MAC Address problems
Log In
Join Now
  • Community Home
  • Community Browser:
  • NETGEAR Website
  • Downloads
  • MyNETGEAR
Log In
  • English
  • NETGEAR Forum
  • Home Networking
  • Join Now
  • Log In
  • Help
Discussion stats
  • 11 replies
  • ‎2015-07-31 03:14 AM
  • 6434 views
  • 7 kudos
  • 5 in conversation
    • netwrks
    • maddavo
    • kochin
    • smallscript
    • qnnskmn
Announcements
Important Security Update from NETGEAR
Would you like to experience the new NETGEAR Orbi 2.1 App?
Arlo Security Light - Smart, Wire-Free Lighting Solution - Spring 2018
Join the NETGEAR Up 2.1 Beta
IoT Reaper - malware attacking NETGEAR devices
Check out The New Facebook Wi-Fi Powered by NETGEAR
Win an Arlo Pro 2 Smart Security System - visit r/ArloSmartHome for Details
Introducing Insight Manager 3.0
Introducing Orbi Pro - Secure and Simple WiFi for Your Small Business
Top Contributors
User Kudos Count
TheEther
Sage TheEther Sage
3
KABL
KABL Tutor
2
scss98
scss98 Guide
2
DirkTr
DirkTr Follower
2
Morpheo
Morpheo Initiate
2
See All
Reply
Topic Options
  • Subscribe to RSS Feed
  • Mark Topic as New
  • Mark Topic as Read
  • Float this Topic for Current User
  • Bookmark
  • Subscribe
  • Printer Friendly Page
  • All forum topics
  • Previous Topic
  • Next Topic
maddavo
maddavo Tutor
Tutor
  • Mark as New
  • Bookmark
  • Subscribe
  • Highlight
  • Print
  • Email to a Friend
  • Report Inappropriate Content
I want to disable the EX7000's allocation of virtual MAC addresses to devices on my network but I cannot find anywhere how do do this.  I am coming to the conclusion that it is not possible.  The virtual MAC addresses are causing me problems.
I have a DHCP server on my network.  The DHCP server allocates reserved IP addresses to devices on my network.  Some devices are wired, some are Wifi.  I bought the EX7000 to extend the range of my wifi network.  The problem is that when a device moves from the existing wifi network to the EX7000's extended wifi network then the MAC address changes to the virtual MAC address.  The DHCP server CANNOT allocate/reserve a single IP address to multiple MAC addresses.  Therefore the devices cannot keep the same DHCP-allocated IP address when moving across wifi networks.  This is extremely frustrating.  Why do we have to use virtual MAC addresses anyway?
I could manually set a static IP address on each device on the two saved wifi networks - but this defeats the purpose of having the DHCP server in the first place.
Is there a way to turn off the EX7000's Virtual MAC address feature or some other way to configure the above network so that devices can move between the wifi and extended-wifi networks whilst keeping their unique DHCP-allocated IP address?
Message 1 of 12
Labels:
  • Advanced Features
  • Installation
  • Troubleshooting
2 Kudos
Reply
netwrks
netwrks Master
Master
  • Mark as New
  • Bookmark
  • Subscribe
  • Highlight
  • Print
  • Email to a Friend
‎2015-08-02 06:00 PM
Re: EX7000 Virtual MAC Address problems
Check out the link below. If you have MAC Filtering enabled on your base router, just disable it. There is no Security in MAC Filtering. The best security is a strong password.
https://community.netgear.com/t5/WiFi-Range-Extenders-Repeaters/virtual-MAC-addresses/m-p/494762#U49...
Message 2 of 12
0 Kudos
Reply
maddavo
maddavo Tutor
Tutor
  • Mark as New
  • Bookmark
  • Subscribe
  • Highlight
  • Print
  • Email to a Friend
‎2015-08-02 06:20 PM
Thanks, but the issue does not have to do with MAC Filtering.  I do not use MAC filtering on my router.  The issue is getting the right IP Address allocated to the right device (which is done by the DHCP server based on MAC Address).  The DHCP server can only reserve a single IP address to a single MAC address - a one-to-one relationship.  The 'Virtual' MAC Address causes devices to have multiple MAC Addresses which then means single static IP address allocation is not possible automatically as far as I can see.
Message 3 of 12
1 Kudo
Reply
netwrks
netwrks Master
Master
  • Mark as New
  • Bookmark
  • Subscribe
  • Highlight
  • Print
  • Email to a Friend
‎2015-08-03 08:26 AM
Yes, that's what the EX7000 and other extender's do. You can't remove the virtual mac address function. Not sure if it's an option for you, but the EX7000 does support AP mode.
Message 4 of 12
0 Kudos
Reply
maddavo
maddavo Tutor
Tutor
  • Mark as New
  • Bookmark
  • Subscribe
  • Highlight
  • Print
  • Email to a Friend
‎2015-08-09 05:05 PM
No, AP mode is not an option - no wired network at the EX7000 location.
So in summary, there is no solution to my problem.  Virtual MAC addresses cannot be turned off so there is no way for the DHCP server to allocate the same reserved IP addresses to wireless devices across the Wi-Fi and extended Wi-Fi networks.  Either each wireless device must be set to manual IP address (not using the DHCP server) OR the DHCP server has to have two IP addresses reserved for each device.
Message 5 of 12
0 Kudos
Reply
kochin
kochin Star
Star
  • Mark as New
  • Bookmark
  • Subscribe
  • Highlight
  • Print
  • Email to a Friend
‎2015-08-26 06:10 PM
Netgear really needs to provide a way to turn Virtual MAC Address feature off. It creates problems on the network. When I move from one extender to the router, my device often fails to acquire an IP address due to the change of MAC. I wonder why Netgear needs to use Virtual MACs. Isn't MAC unique for a device?
Message 6 of 12
1 Kudo
Reply
netwrks
netwrks Master
Master
  • Mark as New
  • Bookmark
  • Subscribe
  • Highlight
  • Print
  • Email to a Friend
‎2015-08-27 07:29 AM
It turns off in AP mode (which you can't use). So yes, if you are trying to make this setup roam, you need to reserve an IP address to the virtual MAC address. The short version. For each connected client, the extender creates a separate session with the upstream Wireless Router.  The Extender generates a virtual MAC on the Upstream side, virtual MAC that can be identified to keep sessions in check. NG is not the only vendor doing this, and is not the only vendor that does not allow disabling of the  Virtual MAC function.
Message 7 of 12
0 Kudos
Reply
kochin
kochin Star
Star
  • Mark as New
  • Bookmark
  • Subscribe
  • Highlight
  • Print
  • Email to a Friend
‎2015-08-27 08:24 AM
Thank you for the detail explanation. I just don't understand why Vitural MACs are needed when MACs are unique. According to my observations, the EX7000 simply replaces the first 3 hex codes in the MAC with 02:0f:b5. I have 2 EX7000s, and both of them do the same thing with MACs. Why don't they just use original MACs?
When connected to my main router R7000, the original MAC is sent to my DHCP server (dnsmasq). When connected to an extender EX7000, a Virtual MAC is sent to the DHCP server. The switch-over seems to confuse some of my WiFi devices. Often they fail to obtain a new IP address and require an off-on cycle or even re-creating profile to obtain an IP address. And, they are not receiving the IP address I assigned due to Virtual MACs. Very frustrating.
Is there a technical reason for requireing Virtual MAC?
Message 8 of 12
0 Kudos
Reply
netwrks
netwrks Master
Master
  • Mark as New
  • Bookmark
  • Subscribe
  • Highlight
  • Print
  • Email to a Friend
‎2015-08-27 08:43 AM
Yes, it is purely technical. Basically, it so that they can keep track of the WIFI sessions between Base router, extender, and client.  Nothing concise on the internet I have found that describe it.
Extenders don't realy work as AP's. It is purley an extension of your wireless network. Not designed to roam, more of connect directly to the extended SSID when you are out of range of your Base router wifi. Then you have the whole client sticking issue, which is a completely different issue
Message 9 of 12
0 Kudos
Reply
kochin
kochin Star
Star
  • Mark as New
  • Bookmark
  • Subscribe
  • Highlight
  • Print
  • Email to a Friend
‎2015-08-27 03:18 PM
@maddavo
I solved one of the problems with Virtual MAC addresses when running my own DHCP server. The DHCP server I am using is DNSMASQ on a Linux server. DNSMASQ actually allows mapping multiple MAC addresses to one IPv4 address.
For example, let's say aa:bb:cc:dd:ee:ff is the MAC address of a WiFi device and 192.168.x.y is the IP to be assigned to it. The Virtual MAC for that device on EX7000 should be 02:0f:b5:dd:ee:ff. So I use the following entry for it:
aa:bb:cc:dd:ee:ff,02:0f:b5:dd:ee:ff,192.168.x.y
The line is saved in a file /etc/dsnmasq-dhcphosts and loaded into DNSMASQ server. (Actually I am using OpenMediaVault with DNSMASQ plugin.) When a DHCP request for MAC address of either aa:bb:cc:dd:ee:ff or 02:0f:b5:dd:ee:ff is received, DNSMASQ server will lease the IP address 192.168.x.y to the requesting client.
Now no matter my WiFi device is connected to the main router or on of the extenders, it will receive the same pre-assigned IP address.
Message 10 of 12
1 Kudo
Reply
smallscript
smallscript Initiate
Initiate
  • Mark as New
  • Bookmark
  • Subscribe
  • Highlight
  • Print
  • Email to a Friend
‎2015-12-07 02:07 AM
I am having exactly the same challenges using MAC addresses to assign IP addresses to centrally administer IPs at the DHCP server (gateway). It is a pain in the butt. I will switch and try the linux DHCP workaround. However, the Netgear solution for extenders is fundamentally broken.
They are basically building a MAC level NAT. As such, the Netgear code should have done the DHCP IP address proxying for the virtual mac addresses (since it already has to negotiate MAC address availability and collision testing as it assigns virtual MAC addresses).
In other words, it should have let the real MAC address straight through for DHCP queries, intercepted, and translated it back to the device with the real MAC address. It should NOT be allowing DHCP queries to go out with the virtual MAC address. That is BROKEN! I am guessing they don't want to masquerade as the real MAC address in their packet filter for DHCP proxying. If that was the case they could have introduced a service into their primary AP that did  the brokering. As it is, it is fundamentally flawed because it makes it very difficult to build a network at any scale with extenders.
Virtual MAC address mapping where a IP address is assigned to a pool of MAC addresses doesn't really help because they have multiple algorithms. It would be great if they had DHCP servers that were virtual MAC address aware since the virtual MAC addresses are algorithmically generated from the real primary MAC address. sigh....
Message 11 of 12
2 Kudos
Reply
qnnskmn
qnnskmn Aspirant
  • Mark as New
  • Bookmark
  • Subscribe
  • Highlight
  • Print
  • Email to a Friend
‎2016-01-31 09:52 AM
That is true there is no security in Mac Filtering. However a "good" network admin would notice a spike on the network of a particular address then investigate. Why make it easier for those who want
to do harm?
Message 12 of 12
0 Kudos
Reply
  • All forum topics
  • Previous Topic
  • Next Topic
Need More Help?
  • Contact Support
  • About Us
  • Investor Relations
  • Contact us
  • Careers
  • Sign Up
  • United States
    • 中国 (汉语)
    • España (Español)
    • France (Français)
    • Italia (Italiano)
    • 日本 (日本語)
© 1996-2018 NETGEAR®
