× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX7300 Extender 2,4 GHz no connection
John-R
My Nighthawk X4 Range Extender (EX7300) suddenly lost the 2,4 GHz connection. I’m renting an appartment, and I’ve connected the extender via WIFI to the landlords router. It’s been working perfectly for nearly a year now, and I’ve kept the extender updated to the latest firmware.
The extender is still extending both 2,4 GHz and 5 GHz, but now the 2,4 GHz is not working and when I try to connect it says «wrong password». I can still connect to the 5 GHz and that works fine.
I’ve tried the following solutions:
- reset to factory settings
- checked for firmware updates
- Tried connecting with different devices
Has anyone encountered similar problems?
Message 1 of 4
DexterJB
NETGEAR Moderator
Re: EX7300 Extender 2,4 GHz no connection
Hi @John-R,
Welcome to the community!
1. Please indicate the firmware version of the extender.
2. Are your devices able to connect to the main network's (router) 2.4GHz network using the same password?
3. Have you tried using a different password for the 2.4GHz band of the extender?
Dexter
Community Team
Message 2 of 4
John-R
Firmware Version: V1.0.2.136
Yes, I’m able to connect to the main router from my devices.
I’ve tried to reset and extend the network multiple times.
So far I’ve tried:
- extending using same SSID/ network name and password as the main router
- extending and creating different names for 2,4 and 5 GHz bands and different passwords for each connection.
The last option has worked for about a year, then suddenly the 2,4 GHz connection is gone. When I log into the extender it says «No connection» in the status window for 2,4 GHz, while the 5 ghz works fine.
Message 3 of 4
DexterJB
NETGEAR Moderator
Hi @John-R,
I have sent you a message. Please check your inbox.
Dexter
Community Team
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1262 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
