Orbi WiFi 7 RBE973
Reply
Enable Access Control
Zirconium
Tutor
There's an option to enable access control for Wifi Devices, but there isn't an option to enable access control for wired devices. Untitled.png
Model: EX7300|AC2200 WiFi Range Extender
Message 1 of 5
Guru
Re: Enable Access Control
Why would you need mac-level access controls for the ethernet port?  Unlike Wifi you have control over physical access.
Message 2 of 5
Zirconium
Tutor
There’s been a few times I noticed some questionable ones that show up in wired that I don’t believe have physical access to. It’s a bit suspicious; especially when some disappear after I do a firmware update or restart the extender.
Message 3 of 5
Zirconium
Tutor
There is access control here for wired and wifi.  I would've thought that kind of control would also be available for the extenders.There is access control here for wired and wifi. I would've thought that kind of control would also be available for the extenders.
Message 4 of 5
Guru
@Zirconium wrote:  I would've thought that kind of control would also be available for the extenders.
I don't disagree with that, but I also don't think you'd need that for wired connections, especially since there is only one ethernet port on your extender.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2407 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
