- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ex3700 WiFi range extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All:
Im going to be staying in my RV in a friends yard and they said I could use their WIFi. I bought the EX3700 at a friends recommendation because they said the ones that plug in boost a better signal. My question is this: because of Covid I cannot go in their house and access their router. Can I just plug this extender in in my RV and set it up that way? I have their Wifi name and password. Any help will be appreciated!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes it is. Its also one of the videos on the support site. video's and manual are found here:
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ex3700 WiFi range extender
Yes you can. Just set it up using the installation assistant.
The 1 issue you might run into is that many campers have a metal exterior that does a very good job of blocking wifi. If you can plug it in with an extension cord and and put the extender in a windows within line of sight of the home, it might get you much better wireless signal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks so much for your suggestion! I’m not very tech savvy so I appreciate the help. How do I go about using the installation assistant? Is that covered in the owners manual?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
