- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ex6200v2 amber
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ex6200v2 amber
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ex6200v2 amber
so the top 3 lights are:
2.4ghz link light
5ghz link light
device--router link light.
what firmware are you on?
have you hardwired into it and reran setup on it to connect it to your router?
what router are you connecting it to ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ex6200v2 amber
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ex6200v2 amber
If its not linking back to the router, you won't get internet. But you can connect to it via ethernet (disable wifi on the device you're connecting with) and then you can log into the settings and check setup status or even rerun setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ex6200v2 amber
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ex6200v2 amber
Which error is it coming up with?
How are you attempting to access it? Details matter since we aren't there to see what you're doing.
Are you able to ping it while connected to it?
Have you reset it back to factory (push and hold reset for 7-15 seconds while plugged in)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ex6200v2 amber
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ex6200v2 amber
you could try recoverying it with tftp.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
