Orbi WiFi 7 RBE973
Reply
Extender Model No. EX6120 purchased at UAE in 2020, product unable to register in Idia
tajmul
Follower
I Purchased the NETGEAR EXTENDER EX6120 MODEL NO. 4D5A8476A0003 in 2020 at Abu Dhabi and not registered the project with NETGEAR.. Now I tried to register the project in India, it is showing the Model number is incorrect.
There are 3 nos on the extender as CC40D00BF9A3      4D5A8476A0003    85469884
IN 4D5A8476A0003   the third degit is no clarity looks like 5 and 6.
HOW DO I REGISTER MY EXTENDER
HOW DO I CONNECT TO MY ROUTER
Message 1 of 2
Guru
Re: Extender Model No. EX6120 purchased at UAE in 2020, product unable to register in Idia
You don't need to register the extender to use it.
You can set it up using the install assistant just fine without registration.
Not sure about broadcasting as each region has its own broadcasting restrictions and if you bought it in one region and brought it to a different, it could create issues.
Did you set it up using the push button WPS option?
If so, factory reset the extender  and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 235 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
