- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Extending range of EX6200
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello there Having recently purchased a EX6200 and linked it to our wifi router in the house it is working fine ! however i have an office out in the garden and i was hoping that the EX6200 would have the range to deliver me wifi but unfortualtly it does not .. i have an apple airport time capsule in the office and was wondering weather i can cable from the EX6200 to the time capsure which has built in airport , would that work and if so what would be the best way to connect the two ? Any help much appriciated !
Many thanks James
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extending range of EX6200
Yes, you can cable the EX6200 to the Time Capsule. Use Ethernet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks would that mean that by linking the 6200 to my airport via Ethernet that my airport would then deliver wifi ? The building is about 30 metres away would I see a lot of drop off via Ethernet over that distance? And if so is there a better way of getting wifi from the 6200 to the building ? Many thanks ..
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can set up your Airport to deliver Wi-Fi. You should set it to bridge mode.
Each Ethernet segment can go up to 100 metres. There is no drop off in speed. Use Cat 5E cable or better.
