×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Force a 5GHz connection from Repeater to Spectrum router
Jeff_Lindstrom
Follower
Our new Spectrum WiFi Router decides whether to connect to a device on the 2.5GHz or 5GHz band based on signal strength and, for the last couple days, it has been choosing the 2.4GHz band for my Repeater, sticking me with a slower speed even though the 5GHz signal is more than adequate.
Fastlane is not an option because I would like to configure the Repeater so that it uses the 5GHz band to connect to the Router, but still has 5GHz and 2.4GHz available for devices to connect to the Repeater (we have a TiVo in the next room with Wireless G that I would also like to connect).
Is this possible?  Or should I just give up on 5GHz WiFi for the upstairs?
Thanks in advance,
Jeff
Model: EX6110|AC1200 Dual Band WiFi Range Extender
Message 1 of 2
Guru
Re: Force a 5GHz connection from Repeater to Spectrum router
Which spectrum router is it?
Many you can disable band steering.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 784 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
