- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Lost Nighthawk app connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
I lost connectivity between my Nighthawk app and my mesh router. The router works and the password to join works, but can't use the app to manage the network. Tried to reset and start over. Didn't work. Suspect something was connected to the wifi, but couldn't see it. Any ideas?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
What mesh network do you have? Model?
what modem/gateway is it connected to?
If you're on mac/ios, make sure to disable icloud relay and private mac/ip address or it can create issues with the app
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Lost Nighthawk app connection
I have the MR60 Mesh router system connected to a new FIOS Wifi6 router. I need to check settings because I do have a Mac. Thanks for that input!
