- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Multiple Range Extenders
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have two questions.
One, if I already have an extender for one floor, can I add a second extender for the basement?
Second, the extender I purchased shows already registered to another user. Anyone know how to reset that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Multiple Range Extenders
1. You can use more than 1 range extender but make sure to set them up in a star configuration and NOT daisy chained.
- star: Extender<-------router------>extender
- Daisy: Router------>extender------->extender
2. If it was already registered and you bought it new, its probably faster to return/exchange it. If you bought it from a person, they can have it deregistered from their account.
3. you should be able to still install it even if registered. Just factory reset it. Push and hold reset for 7-15 seconds while powered on.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
