- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
N300 Extender Authorization problem when using Acer Iconia tablet..
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought the range extender so I could use my Nokia Windows smart phone. It works fine and I can select either the router wifi signal or the extender from my phone, but when we use my wife`s Acer tablet can only connect via router wifi.
Both the router and extender signals are detected by the tablet but when trying to access the stronger extender signal it says we have an Authorization problem.
What is the problem? nothing seems to tell me
Both signals are using the same password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: N300 Extender Authorization problem when using Acer Iconia tablet..
Hello Pellattuk
You should have them with diffrenet SSID if they are the sam SSID they could cause issues.
DarrenM
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
