Johncheetham
Sep 07, 2018Aspirant
N300 Wifi extender wont accept password and no Router Link LED
I have the N300 Wifi Range Extender WN3000RPv3.
Using my iphone or Ipad, and using my Routers Password, the Extender says it is incorrect. If I type mywifiext.net it says "You are not connected to your extender's WiFi network." The only lights are Power and WPS, no Router Link or Client Link
Did you try unplugging it, and then plugging it in again?
Can you connect a laptop to the extender's ethernet port? That should let you reach mywifiext.net.
- JohncheethamAspirantThanks guys. I found by holding the reset button for 7 secs that cured it.
Great!
