× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Netgear AC750 configuration
fredaa
Follower
I installed the Netgear Extender AC750 and connected a device to it which is working, i.e., the device is connected to the network  The next step in the WEP installation instructions are” Connect any WiFi enabled device like you would connect them to your main network, using the credentials below.”  When I do that I get the following 2 error messages.
The requested URL /IA_review_setting.htm was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
What should I do?
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Netgear AC750 configuration
Hello fredaa
Are you not able to connect devices using the wireless password and not just the wep?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1818 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
