Reply
Netgear EX2700 Poor Signal issues
TonyFG1971
Hi,
I’ve connected my Booster to my Router in my Lounge (Ethernet 100mb Internet) & home Network, with the Booster plugged in the my Sons bedroom (in same floor, as live in a Flat) so he can play online games with his friends, but the signal strength isn’t good enough so not happy . HELP pls.
Any ideas guys?
Cheers,
Tony
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 1 of 4
Guru
Re: Netgear EX2700 Poor Signal issues
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RBRE960(v.85) and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 4
@TonyFG1971 wrote:
Hi,
What is that router?
Is he using wifi or plugging into the Ethernet port on the EX2700?
You might find that Powerline Ethernet is more reliable.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 4
TonyFG1971
Thank you.
I have a Virgin Hub 3 Router (Arris Group).
Can I check that if my Router is in my Lounge & Booster in a Bedroom that it would be better to connect a cable from the Booster to my PS4 to improve the speed?
Also, do Wi-Fi channels make a difference, as I’ve got everything set up auto channel optimise?
This however doesn’t allow me to specify 2.4G instead of 5G which I believe is better when further away?
Thanks,
Tony
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 257 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
