Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear EX7500 Setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-03-06
01:57 AM
2023-03-06
01:57 AM
Here are the steps to set up your Netgear EX7500 WiFi extender:
- Place the extender: Place the extender in the same room as your router.
- Power on the extender: Plug the extender into an electrical outlet and turn in on.
- Connect to the extender: Use a computer or mobile device to connect to the extender's wifi networK. The default network name and password can be found on the extender's label.
- Connect the extender to the router: Once connected to the extender's Wifi network, open a web browser and enter the default IP address for the extender (192.168.1.250) in the address bar.
- Log in to the extender: Enter the default login credentials to access the extender's web interface.
- Follow the setup wizard: The setup wizard will guide you through the process of configuring the extender. You will be asked to select your router's wifi network and enter the wifi password.
- Complete the setup: Once the setup is complete, the extender will reboot. you can now move the extender to the desired location and connect your devices to the extended network.
Watch on youtube: Netgear EX7500 Extender.
Note: It's recommended to place the extender midway between the router and the area where you want to extend the WiFi coverage. This will help ensure optimal coverage and performance.
Message 1 of 1
Labels:
Announcements
