magma's avatar
magma
Netgear WGR614v10 repeating does not work-please help
Hello all
i purchased 2 brand new netgear WGR614v10 routers specificallyso i could repeat wifi signal
howevr i have been disappointed with the result
router1 is connected to my broadband modem and is my master
the other router is bought specifically for repeater duty
i have followed every step of the following tutorial
http://support.netgear.com/app/answers/detail/a_id/965
however my notebook just cant seen to connect through the repeater
i.e the repeater is useless
following are the setting on my base station
basic setting
internet IP : get dynamically from ISP
DND : get automatically
wifi setting
SSID : skynet1
region asia
channel 1
mode uto 150mbps
security WEP
encryption 64bit
KEY1 : 0920439***
wireless repeating function
base station is selected and the MAC address of my 2nd router (repeater) has been entered correctly from the sticker on its rear
LAN setup
IP 192.168.1.1
DHCP range
192.168.1.2 to 192.168.1.98
Following are the setting on the repeater router
wifi setting
SSID : skynet1
region asia
channel 10
mode uto 150mbps
security WEP
encryption 64bit
KEY1 : 0920439*** (same as that of the base station)
wireless repeater is selected and the MAC address of my 1st base router has been entered correctly from the sticker on its rear
the repeater IP shown is 192.168.1.99
LAN setup
IP 192.168.1.99
DHCP - is greyed out ( this happens automatically when i selected the repeater function)
the above setup does nto work
though the repeater is centred in my house
though i can conect to skynet 1 from all parts of the house except a few - the signal is very weak and drops many times - basically i am connected to the BASE station NOT the repeater
to make sure of this i turned off the repeater - i get the same weak signal
turning on the reapeater does NO good
i still have the same weak signal that drops
NOW if i hard wire the base station to the repeater and hard wire the repeater to my notebook - everything woeks fine and dandy through the hard wire
BUT wifi
thats a complete no no
i have also tried giving the repeater a differnt SSID
say skynet2
when i do this
i cant seem to connect to skynet2 manually from my notebook even when i stand next to the repeater when i do this
PS i have tried different combinations of IPs too keeping in mind the DHCP range etc
still doesnt work
what am i missing?/doing wrong
help would greatly be appreciated
i assume i dont have to flash dd wrt since this router is already meant to be used as a repeater etc
