× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear WN 2000 rptv
nteah
After updating the software, the extender does not accept the login and password.
Model: WN2000RPTv3|WiFi Range Extender
Message 1 of 6
jvasanth1984
Virtuoso
Re: Netgear WN 2000 rptv
Hi @nteah,
                  Did you tried user name as "admin" and password as "password"? If you have changed it and it you are sure that you are trying the correct credentials, reset and reconfigure the extender.
Message 2 of 6
nteah
It did not assist. I guess I'll have to do a hard reset.
Model: WN2000RPT|Universal WiFi Range Extender
Message 3 of 6
jvasanth1984
Virtuoso
Hi @nteah,
                  Did you performed hard reset and tried setting it up again?
Message 4 of 6
nteah
I did a hard reset. The light blinks and it does not work after. Then I let it match with the main router via WPN it works. I am trying to link it via ethernet and to do that I must be able to log in.
Message 5 of 6
jvasanth1984
Virtuoso
Hi @nteah,
                  Since you have already completed setup using WPS, try to login to it using mywifiext.net or IP address which your router assigned to it to access its settings. But, internet should be working already if setup was successful using WPS.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 727 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
