- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Wifi Extender Not Working
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Wifi Extender Not Working
What model number router? Firmware on it?
Firmware on extender?
Does the extender led lights show its connected back to the router?
Do you get internet on the router?
First thing I'd do is make sure both firmwares are up to date. Then I'd start fresh. factory reset both devices (hold reset button 7-10 seconds while powered on, lights should flash/blink/change when the reset starts)
Then setup the router with the basic settings. What I mean is get your internet working, setup your wifi, and leave it as is until you can setup your extender. Also, make sure you setup the extender in the same room while doing the setup process. You can move it to a different location once its setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes the extender is connected to the router, and the router is getting 200mbps.
I've tried doing the reset on the router and the extender, and nothing has seemed to fix the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What firmware is it on both? numbers help.
how do you know the extender is connected? Is the router assigning an IP address?
If you hardwire into the extender, does it work?
