× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear n300 ex2700 wifi extender says password is incorrect
BenParkes
Hello
Basically my router says "incorrect password" even though it is definitely correct. So I factory reset the router, reconnect to the router using the WPS button and it works again. Then after about a week it will start saying incorrect password even though it is definitely correct. The firmware is update. Does anyone have any suggestions? Thanks in advance.
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 1 of 4
Guru
Re: Netgear n300 ex2700 wifi extender says password is incorrect
Suggestion 1? Factory reset the extender and re-run setup using the installation assistant and not using wps. wps gets coded different between different manufacturers.
Message 2 of 4
BenParkes
Hi, thanks for your suggestion. How do I set up using the installation assistant?
Message 3 of 4
Guru
on the support site its the 2nd video in the series.
https://www.netgear.com/support/product/EX2700.aspx
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 880 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
