× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Network password not working on brand new N300 - EX2700
mbav1
Follower
Hello everyone, I recently purchased a N300 (MN:EX2700) and connected it via the WPS button on my Technicolor TG582n router, which connected easily with no issues. However, when I come to log in and enter my usual network password (as instructed), it is rejected as incorrect. But i'm sure that is is the correct password. I have even gone to the extent of using keychain on my MAC (version: 10.11.4) to make sure the password is right. I have also tried connecting on various other devices - laptops, phones and streaming devices - none will connected. any advice would be much appreciate! 🙂
Message 1 of 2
Guru
Re: Network password not working on brand new N300 - EX2700
Try resetting and re-installing using the installation wizard and not wps. not all manufacturer's code wps the same and it can cause issues.
what firmware is on your extender?
Also check your router forums as some routers work poorly with extenders.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 259 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
