Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk EX7500
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-04-08
01:24 AM
2021-04-08
01:24 AM
Nighthawk EX7500
Hi
Im trying to connect the extender to my BT hub
It connects through 2.4Ghz but not through 5Ghz
The BT hub only offers channels 36, 40, 44 & 48 at 5GHz
How do I force the extender to connect through one of these channels and not the default channel 100?
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-04-08
07:33 AM
2021-04-08
07:33 AM
Re: Nighthawk EX7500
Which bt hub do you have?
Are you installing using the installation assistant or using WPS?
i'd try factory resetting (push and hold reset for 7-15 seconds while its powered on) and then install using the installation assistant.
That allows you to select the network when setting up 5ghz.
Message 2 of 2
Announcements
