- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X4 - Will new router recognize the original Nighthawk settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm trying to take the easy way out. I just upgraded my Verizon router. I'm hoping the new router will recognize my original Nighthawk and it's settings. Or, will I have to reset and reconfigure my Nighthawk's settings? If so, where can I find the proper instructions? Thanks for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk X4 - Will new router recognize the original Nighthawk settings
This was a whole confusion of a post.
Did you have a netgear router and upgrade? If so, what did you have and what did you buy?
I'm not sure what the Verizon router has to do with it.
Usually, when I replace my router, I reuse the same SSID. This allows devices just to connect automatically.
In terms of settings, backups usually aren't transferable between devices because there's hardware differences. If that's what you're referring to. Not sure as your post jumps around a lot.
