× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Nighthawk x4s
Kay01
Nighthawk x4s
Extender was working great for 8 months but now no longer working. Only light on is power. I have reset but still nothing. Can't recognize router now which is a cisco. I have not changed any settings.
Original set up was a nightmare but Netgear was able to help out. No longer under warranty and they want $90 to help.
Model: EX7500|AC2200 Nighthawk X4S Tri Band WiFi Mesh Extender
Message 1 of 7
Guru
Re: Nighthawk x4s
Are you trying to reinstall it using the wps method of install or using the smart installation wizard?
I'd highly recommend setting it up via the installation wizard when you're using a router from a different manufacturer.
Message 2 of 7
Kay01
Re: Nighthawk x4s
Can't locate the smart wizard. Do you have a link. I did the guided assistance but still can't connect.
Message 3 of 7
Guru
Re: Nighthawk x4s
The support site has an install video. I think its the 2nd video if you click the over button. About 2 minutes in, it shows the installation wizard being used.
https://www.netgear.com/support/product/EX7500.aspx
Message 4 of 7
Kay01
Re: Nighthawk x4s
Thanks. I found it and was able to get the wifi light to go on but still nothing. I liked this product but this is too time consuming. It will be returned.
Message 5 of 7
Guru
Re: Nighthawk x4s
You also have the option of contacting support for free if you're within your free 90 days of support (from date of purchase)
Simply click mynetgear at the top, register an account, and then the device. From there you can contact support.
Message 6 of 7
Kay01
Re: Nighthawk x4s
Thank you, Yes I did call support but since it's not within the 90 days I need to pay $90 for someone to help. If it in fact is a defected extender they will not do anything since it's not within the 90 days. So seems like I should put the $90 towards a new extender. Thought I should have gotten more than a year out of this product.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 853 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
