StillNoIdea's avatar
StillNoIdea
Initiate
Jan 21, 2019
Powerline PLW1000v2 not connecting to router
Hi there
I just got a new router and modem after they both crashed.  Now my powerline adapter won't connect to internet.  All the lights show that it is connected to the router (all green) but it isn't getting any internet through it.  Should I factory reset and if so, does that mean the password changes from the one on the back of the adapter?
Thanks in advance.
  • Hi Blanca
    Thank you for your advice.   As it turns out.  The service providers who came to install the new Router and Modem had a cable in one of the router's ports and then the other end of the cable in another..... unbelieveable!  Anyway, once I removed the cable it all worked.
    Regards
    Stillnoidea :)
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi StillNoIdea
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
    Blanca
    Community Team
    • StillNoIdea's avatar
      StillNoIdea
      Initiate
      Hi Blanca
      Regards
      Stillnoidea :)
      • Blanca_O's avatar
        Blanca_O
        Hi StillNoIdea
        Thank you for your feedback.  Glad that it's working now.
        Blanca
        Community Team
