grammary's avatar
grammary
Problem with setup for Model EX6120
My router has wps and after I plug in my extender and turn on the wps on the router and extender, the light on the router stays blinking and then turns off.  It never stays green indicating the connection.  What am I doing wrong and how can I get it connected???
      • michaelkenward's avatar
        michaelkenward
        What wireless security do you have on the router? WEP won't work with WPS.
        Are you doing it in the right order?
        Any chance that WPS is disabled in the router?
        There is a manual for the device somewhere at the end of this link-
        >>>> EX6120 | AC750 WiFi Range Extender | NETGEAR Support <<<<
        See page 11.
        It might be easier to do it with the web browser.
