× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Range Extender ex6250 How to use wired connection rather WIFI
sesunbird
Hello.
Configured my range extender and working in wifi mode.   Would like to use the Ethernet port for incoming signal from switch instead Wifi. Everytime in connect the wire cable, all internet in the house slow down deeply. once disconnected, everything come back normal.  BTW, switch on the side is alway on extender mode, NOT acess point.
Model: EX6250|AC1750-WIFI MESH EXTENDER
Message 1 of 4
Guru
Re: Range Extender ex6250 How to use wired connection rather WIFI
If you're wanting to hardwire it in, you need to set it to AP mode. Or you'll get the problem you're experiencing.
Message 2 of 4
sesunbird
So Range Extender= use wifi signal to broadcast further the same SSID
Acess point= use wire to make a distant connecting point and use the same SSDI.
am I correct?
Message 3 of 4
Guru
am I correct?
for the most part. I usually don't recommend using the same ssid for extenders but it isn't a hard rule. Just a preference.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1486 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
