- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Renaminng Host Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wish to rename the host router. Password and other information remains the same. What must I do, if anything, to the Range Extender to maintain a connection? N600 WiFi Range Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Renaminng Host Router
Why? Is there some actual problem which you are trying to solve?
Which name? The router itself? The wireless network name (SSID)?
"N600" is a speed, not a model number. Ever helpful, Netgear product
packaging emphasizes speeds like "N600", but that's not the model
identifier.
To what is this "N600 WiFi Range Extender" connected?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Indeed, it is the SSID which I desire to change.
No Problem with the current name; I merely wish to change it.
The Model is WIN2500RP
The Host Router is a D-Link DIR 825. This should not be an issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
WN2500RP? WN2500RPv2?
http://netgear.com/support/ [Put in your model number.]
For the older one:
http://netgear.com/support/product/WN2500RP.aspx
http://www.downloads.netgear.com/files/GDC/WN2500RP/WN2500RP_UM_9Nov12.pdf
Page 16, "Extender Wireless Settings":
You can use the Wireless Settings screen to change the network
name (SSID) for the extender's network and to set up wireless
security. [...]
