Orbi WiFi 7 RBE973
Reply
Repeated Disconnecting & Connecting
pdxskip
Novice
Occasionally while I'm using my laptop, I notice that the connection to my EX6100 extender disconnects and then within seconds reconnects. This can happen repeatedly for several minutes. It just happened to me a few minutes ago, but now things appear to be stable. How can I debug this problem? It's a real pain when I'm trying to get something done. Any ideas on where the problem might lie?
Message 1 of 5
Babylon5
NETGEAR Employee Retired
Re: Repeated Disconnecting & Connecting
Do any other wireless devices have issues at the same time? Does the EX6100 have a log file?
Message 2 of 5
sandand
This is what the console on my MacBook returns, when it gets disconnected from the extender network. I'm using WN3000RPv2. As you can see, the connection quits at 11:32:45 and then resumes at 11:34:28.
Maybe, is there an issue here when "stealth mode" is enabled in security preferences of the OS X operating system?
15-05-03 11:30:08 Firewall[74] krb5kdc is listening from 0.0.0.0:88 proto=6
15-05-03 11:32:45 Firewall[74] Deny LaunchCFMApp data in from 192.168.0.197:61701 to port 2222 proto=17
15-05-03 11:33:06 Firewall[74] LaunchCFMApp is listening from 0.0.0.0:3323 proto=6
15-05-03 11:34:18 kernel AirPort: Link Down on en1. Reason 4 (Disassociated due to inactivity).
15-05-03 11:34:18 Things[435] network reachability has changed: not reachable
15-05-03 11:34:18 configd[39] network configuration changed.
15-05-03 11:34:19 [0x0-0x23023].com.google.Chrome[277] [277:25347:0503/113419:ERROR:connection_factory_impl.cc(335)] Failed to connect to MCS endpoint with error -106
15-05-03 11:34:23 Firewall[74] krb5kdc is listening from :::88 proto=6
15-05-03 11:34:23 Firewall[74] krb5kdc is listening from 0.0.0.0:88 proto=6
15-05-03 11:34:28 kernel AirPort: Link Up on en1
15-05-03 11:34:29 kernel AirPort: RSN handshake complete on en1
15-05-03 11:34:31 Firewall[74] krb5kdc is listening from :::88 proto=6
15-05-03 11:34:31 Firewall[74] krb5kdc is listening from 0.0.0.0:88 proto=6
15-05-03 11:34:40 [0x0-0x23023].com.google.Chrome[277] [277:25347:0503/113440:ERROR:connection_factory_impl.cc(335)] Failed to connect to MCS endpoint with error -106
15-05-03 11:34:44 Things[435] network reachability has changed: reachable
15-05-03 11:34:44 configd[39] network configuration changed.
15-05-03 11:34:48 Firewall[74] Stealth Mode connection attempt to UDP 192.168.0.197:5262 from 192.168.0.1:53
15-05-03 11:34:48 Firewall[74] Stealth Mode connection attempt to UDP 192.168.0.197:63606 from 192.168.0.1:53
15-05-03 11:34:48 Firewall[74] Stealth Mode connection attempt to UDP 192.168.0.197:59695 from 192.168.0.1:53
15-05-03 11:34:48 Firewall[74] Stealth Mode connection attempt to UDP 192.168.0.197:61429 from 192.168.0.1:53
15-05-03 11:34:48 Firewall[74] Stealth Mode connection attempt to UDP 192.168.0.197:50196 from 192.168.0.1:53
15-05-03 11:34:48 Firewall[74] Stealth Mode connection attempt to UDP 192.168.0.197:64605 from 192.168.0.1:53
15-05-03 11:34:52 Firewall[74] krb5kdc is listening from :::88 proto=6
15-05-03 11:34:52 Firewall[74] krb5kdc is listening from 0.0.0.0:88 proto=6
Message 3 of 5
sandand
I think this is the reason. Can anybody tell if it is the MacBook or the extender that is "dissacociating" due to inactivity?
Message 4 of 5
Fairytail
Virtuoso
To verify if its the extender, connect a device wired to the extender. If the wired device is disconnected which means the disconnection happens on the extender.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 11005 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
