DerpDerek
Sep 19, 2016Follower
The NETGEAR AC1200's led power light stays amber
Hello I have the AC1200 Dual Band Wifi range extender model ex6120 and the led power stays amber and I have tried everything including waiting and reseting, I need help I just recently bought it
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello DerpDerek
You could try to load a firmware via TFTP to see if you can unbrick the unit if not you will have to contact support. Here is a link on how to do this via TFTP.
DarrenM
