× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Using same SSID as router
arrowgant
Follower
Hi I have a nighthawk 1900 router and got Netgear E6100 to use as extenders. I have used other extenders in the past where I have used the same SSID as the router - and I have not noticed a significant performance degradation. But when I do the same with E6100, my speed drops down to 2 Mbps from >50 Mbps when using separate. I expect some degradation, but this seems extreme.
Netgear recommends against using the same SSID explicitly (pop up when you try to change the name). But has anyone done this with a 6100? Do you see the same extreme drop in speed? Anyone know other configs that I may have to look at? Thanks in advance for any help I can get!
Message 1 of 2
Fairytail
Virtuoso
Re: Using same SSID as router
Have you tried changing channels? Try as well to enable the fastlane technology.
http://kb.netgear.com/app/answers/detail/a_id/24695
Message 2 of 2
Discussion stats
  • 1 reply
  • 5796 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
