× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
WG103 firmware
jscamba26
WG103 firmware
Has the firmware version 2.0.37 been removed from the Netgear download?
I only see version 2.0.25. Is there some issue with 2.0.37?
http://support.netgear.com/app/products/model/a_id/8123
Message 1 of 4
jmizoguchi
Virtuoso
Re: WG103 firmware
contact support at my.netgear.com
Message 2 of 4
rich205
Novice
Re: WG103 firmware
Did you have any look finding the later firmware version? Ill contact support for it now but I need it for setting 16 of them up with a wms5316.
Riich
Message 3 of 4
Jakes
Re: WG103 firmware
I found that version 2.0.37 has a bug on Point-To-Point links. It configures fine but does not reconnect after a reboot. And to make things worse V2.0.25 seems to have a bug of dropping a packet every 7-10 Seconds. Have done some extensive testing on PTP connections and have not found a solid solution for the problem. 2.0.37 gives a stable connection but after a reboot connection does not re-establish. Currently running with 2.0.25 as it at least gives me some sort of connectivity.
Anyone that has a solution for this? Yes I even bought a 3rd WG103 to make sure it is not hardware. Definitely a FW issue.:mad:
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 9546 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
