× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
WN2000RPTv2 only does 26 kB/s
Jeffjohnw
Several years ago I installed a WN2000RPTv2 extender.  It basically works but bandwidth seems slow.  I recently downloaded an app on my Android (Speedtest) and it shows the extender download at 26 KB/s while Xfinity unit that I am trying to extend shows 1.6 MB/s.  My question is basic (I am not an expert in this area):  Is this what to expect from this extender?  Did I set it up incorrectly?  Or if I want more bandwidth do I need to get a newer unit?
Thanks!
Jeff
Model: WN2000RPTv2|Universal WiFi Range Extender
Message 1 of 3
TheEther
Guru
Re: WN2000RPTv2 only does 26 kB/s
26 KB/s seems really low.  It's possible that radio interference has increased over the years.  Your neighbors may have deployed their own Wi-Fi networks.  Baby monitors and certain cordless telephones also interfere with Wi-Fi.
I would first try changing the Wi-Fi channel used by your extender and/or main router.  There are loads of tools that can help you survey your area for the best Wi-Fi channel to use.  Macbooks have built-in tools (option click the Wi-Fi icon).  Windows has free tools like vistumbler.net and Acrylic Wi-Fi.  iOS has a free Wi-Fi scanner in their Airport Utility.  Android, I'm sure, has something, too.
Try moving the extender closer to the router.
If these don't help much, then a newer model may help.  If your router supports 5 GHz, then a dual-band extender can make a big difference.  While 5 GHz has less range, it is generally much less used by people, so it may be a way to escape a crowded, 2.4 GHz spectrum.
Message 2 of 3
Jeffjohnw
Thanks very much for the advise.  I will download a tool and test further.  Jeff
Message 3 of 3
Discussion stats
  • 2 replies
  • 2574 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
